Sponsored by: CARiD
Help! I really messed up.
Old Mar 11, 2023 | 10:15 PM
Coldwater's Avatar
Default Help! I really messed up.
I was working on what should have been a simple project today. Channing out my valve cover gaskets. I had two bolts break off on me. They are also in really hard to reach places with tools. I tried to drill one bolt out and use an extractor. I broke the drill bit and it jumped and messed up the block a bit. I also broke off two extractors in the hole. I fear I need to tap this hole now. I had a damn hard time using a center punch and hammer so I was off center to start with. I’m at a loss of how I should proceed. Should I just send it to a mechanic and have them fix this so I stop f’ing it up?
Old Mar 12, 2023 | 03:21 PM
Harvlr's Avatar
Too bad you got the one drilled off centre. The concentric one might come out if you drill a bit deeper, then heat the casting up with a heat gun and use another screw extractor. Use as large a screw extractor that you can. Get the casting quite hot.
Old Mar 12, 2023 | 03:22 PM
Harvlr's Avatar
Also you should post this in the section of the forum appropriate to your vehicle. You’ll get more traffic there.
Old Mar 13, 2023 | 08:29 PM
tracyc's Avatar
No offense intended, but yes, you should stop and send this to a trusted mechanic. Of course, that's just my opinion, but you asked
Old May 5, 2023 | 11:22 AM
severiano's Avatar
Defendit..
Jul 5, 2023 08:37 AM
Brandon318
Jul 28, 2021 10:47 AM
Elrobo
Jun 16, 2021 08:31 AM
AGLR
Apr 14, 2020 11:32 AM
adolfojbonilla
Jun 10, 2017 09:39 PM
