help key will not turn l322
If the battery has been verified good, I would disconnect the neg. terminal for a few minutes and then reconnect. If the key will now turn on, leave key in igniting and it will Work until you replace the control. Alternately the cpm fuse behind the glove box can be removed then replaced.
on
1 Post
oap_the_disco_3 (12-04-2020)
