help key will not turn l322
hi i have got a range rover l322 04 reg and the ignition key will not turn. the batt is ok and all the fuses are ok too. all so the srs light as came on very dim on dash. all this happened at same time please help
If the battery has been verified good, I would disconnect the neg. terminal for a few minutes and then reconnect. If the key will now turn on, leave key in igniting and it will Work until you replace the control. Alternately the cpm fuse behind the glove box can be removed then replaced.
