Sponsored by: CARiD
help!!!!!!! please
Old Jan 1, 2013 | 06:07 PM
Go back and double check your work.
Did you use cheap plug wires?
Old Jan 1, 2013 | 06:22 PM
dobe1canobe's Avatar
yes i did use cheaper wires not the cheapest though?
Old Jan 1, 2013 | 07:39 PM
If you used Autolite plug wires they are usually crap right out of the box.
Plug wires make more of a difference than plugs do.
I hate to say it you are going to need to replace the plug wires again.
Order Kingsbourne plug wires or Magnecore, both of those are very good.
You will need to replace your plugs again too when you replace the plug wires again.
Cheap plugs are fine, cheap plug wires are not.
Old Jan 2, 2013 | 02:07 AM
ok so i found an exhaust leak driver side before o2 sensors. only drove it for about 10 mins but idle seemed alot better. ill let you know what goes on after 50-100 miles. oh and the vibration was my front driveline u joints. now hopefully i can get this check engine light off lol! thanks mike and spike for all you info!! much appreciated.
Old Jan 2, 2013 | 07:14 AM
Deal with the front drive shaft U joints first and quickly. When it splits, it will poke big hole in tranny.
Old Jan 2, 2013 | 01:58 PM
yes i did them last night. actually very easy to do on this rig. thanks for the info
Old Jan 2, 2013 | 02:49 PM
robersonb's Avatar
Default replace plugs
Spike
Why do you need to change the plugs if you replace the wires? Especially if its done close together. Not saying its wrong, just don't understand why they would need to be changed.
Paul Aspen
Nov 4, 2013 02:10 PM
tarpon66
Jul 27, 2011 12:38 PM
sawadeh
Jul 2, 2011 08:10 PM
Speed racer
Oct 11, 2008 10:56 PM
