Sponsored by: CARiD
Help wont start.3 hrs from home
Old Jun 3, 2016 | 09:20 PM
StaceyBritton1970@gmail.com's Avatar
5th Gear
Default Help wont start.3 hrs from home
Stopped at store come out won't start starter checked good,...signal lights quit....now fuel pump doesn't come on....it checked out good tho.possibly security I tried recommendations listed I must be doing it wrong or 1515 not code.only owned 1 week.no code left by previous owner.please help.frustrated broke and wanna go home.97 discovery
Last edited by StaceyBritton1970@gmail.com; Jun 3, 2016 at 09:28 PM. Reason: Left out vital info
Old Jun 3, 2016 | 09:44 PM
ihscouts's Avatar
Sounds like a dead battery, try wiggling the battery wire clamps to see if it's just a loose connection. See if you can get the battery jumped.
Old Jun 4, 2016 | 12:27 AM
5th Gear
battery is new disco cranks but won't start
Old Jun 4, 2016 | 08:51 AM
abran's Avatar
Where are you located, maybe a member can help? Crank position sensor maybe. I can't remember if the symptoms are the same for D1 as D2.
Old Jun 4, 2016 | 09:46 AM
5th Gear
Default Help...
not sure what we did...but it's back on rd.just now.we pushed the fuel cutoff switch for 5 seconds and messed with starter switch__(just turned it from position 1-3 but not turning it all way over several times)fuel pump began to work again.
Old Jun 14, 2016 | 12:13 AM
5th Gear
Default Update...
update... Seems that there was a kink in wire connected to the fuel pump that when jarred just a little it would prevent pump from working. Apparently needs some new wiring work for sure.
disconic
Jun 4, 2016 02:57 AM
gribur
Sights N Sounds
Feb 9, 2014 10:31 PM
94svt50
Aug 27, 2013 03:17 PM
Sea Paddler
Aug 27, 2012 02:32 PM
gustav23
Dec 15, 2011 01:12 PM
