Sponsored by: CARiD
HELP!!!!!!!! WONT START!!!!!!!
Old Sep 9, 2006 | 03:52 PM
djrazr's Avatar
4th Gear
Default HELP!!!!!!!! WONT START!!!!!!!
first off its an 02 HSE and im in california
I'll first start a couple months ago. Battery died on me so i got a new one at the dealer. Put in new battery and right after i put in the new batter
1) i cant alarm RR from remote
2) a/c stopped blowing cold air
3) nav stopped working
4) windows not set
5) radio worked but can't adjust volume up or down
i fixed the windows but nothing else
Just the other day, she would not start. I started getting gear box fault, abs fault, a clacking noise, and lights flashing, then all of a sudden i could arm my alarm from my remote so something went crazy. I took the battery in and had it tested = bad battery
Took the battery back to the dealer to get it xchanged with no problem. So now i go to pop my hood from inside and now the hood wont open. The left side of the hood pops up but not the right drivers side. The right side is shut closed and i dont want to tweak the hood. All im trying to do now is install this new battery and see what happens but i cant open my hood
suggestions please
Old Sep 9, 2006 | 04:27 PM
Default RE: HELP!!!!!!!! WONT START!!!!!!!
Have someone pull on the hood release while you push the hood down then try an open it. Once you get it opened, get some grease on the latch so it won't stick again.
You really need t get the truck into the shop, are you still under warranty?
Mike
Old Sep 9, 2006 | 04:39 PM
djrazr's Avatar
4th Gear
I got the hood open finally. Does anyone have a fuse placement link? When i took out the old battery, i was checking fuses under the hood and noticed i may have placed some fuses in the wrong spot. I dont want to hook up this new battery and have something else go wrong if i blow a fuse. I dont have an owners manual so if someone can provide a link, that would be great. I want to make sure i put the fuses back where they were suppose to be. Double check
No it's not under warranty.
Old Sep 9, 2006 | 05:32 PM
Turn the fuse box top over, it will show you all the fuse, there location and requirement.
Mike
Old Sep 9, 2006 | 08:16 PM
djrazr's Avatar
4th Gear
i dont have a fuse box cover lid
i have the RAVE cd and i went through all 1362 pages or so and can't find anything. all i can open up is the workshop manual. i cant open electrical troubleshoot, overhaul, owners manual and and in car entertainment, even though i can see them on the disc, i cant open
if anyone can assist me, that would be great. i dont have a fuse box cover lid so i asking for assistance here
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
monk
Oct 19, 2008 10:04 AM
jonsimon
Jan 29, 2007 01:55 PM
