Sponsored by: CARiD
How I fixed my Land Rover tick (slipped sleeve)
Old Oct 10, 2016 | 11:14 AM
  #141
Directfreak's Avatar
Actually,
Is there anyone who could do this for me in
South Florida? It's worth it to try to fix before
making a brash decision.
Please advise me ASAP.
Thanks.
DirectFreak@hotmail.com
Old Mar 22, 2017 | 04:18 PM
  #142
Tony Luna's Avatar
Originally Posted by LR03NJ
Thank you. I just got my UltraGuage and for few days I was using it. After reading this thread, I started the engine and idle to warm it up and found out that around 168 degrees the ticking started and it was soft until it reached 200 when the tick got louder. But definitely I would like to try any solution even the inline fix to see if it will work on mine or even just to lessen the ticking. Also, where can I find the post or article to do the way you solved it? I tried googling it but there are none specific to which is the working solution but thanks again in advance.
I've done a ton of work to my now 212K '04 4.6 (new head gaskets, oil pump, cam, lifters, push rods, rockers, timing gear, radiator, water pump, crank and rod bearings, etc,) and successfully kept the dreaded tick at bay for a couple of years. Runs great! Good oil pressure and compression on all cylinders. No coolant leaks. Biggest bang for the buck in keeping the tick quiet was the in-line 180 degree t-stat. Temps run anywhere from 180 to 194. Tick came back a couple of weeks ago. Cannot stand it - I'm pinning it!
Most likely going to pull the motor, disassemble, deck and hot tank, and replace the cam bearings (just about the only thing I haven't done).
Just sent the OP of this excellent post a PM to see if his pin job is still holding 5 years later - be nice to know...
Old Mar 22, 2017 | 05:17 PM
  #143
Tony Luna's Avatar
OP just got back to me - still running!
Thanks, Tim!
T
Old May 11, 2018 | 01:05 PM
  #144
2Guinness's Avatar
My 03 Disco 2 was clacking so bad it was embarrassing to drive it. I took my motor out and disassembled it for sending off for new topped sleeves. Reading this changed my mind completely. I have the bare block on an engine stand in my garage now and will drill and pin this weekend, saving me thousands.
Thanks to everyone involved.
I will report the success.
Old May 13, 2018 | 10:50 PM
  #145
No Doubt's Avatar
Sounds good. I had the tick, however, and it wasn't the sleeves. When I did my rebuild I lapped the valves and replaced the valve stem seals.
While replacing those valve stem seals I noticed that one of the springs was rubbing against metal in the head. There were even small head shavings at the base of the spring from where the rubbing had caused flakes.
So I ground away the errant metal such that the spring would not rub the head.
Put it all back together and no tick.
Also, my rockers were making a lot of noise. After the rebuild I had much higher oil pressure and I also added Turbo Maxx to my oil. Result: quiet rockers.
Here's a pic of the metal area in the head where the spring was rubbing and the small bits of flakes were being shaved by one of the valve springs:
Attached Thumbnails How I fixed my Land Rover tick (slipped sleeve)-valvespringcontactrubbing.jpg
Old May 16, 2018 | 08:50 AM
  #146
dakirkpa's Avatar
3rd Gear
Default Pinned Sleeves
@2Guinness
I did my Disco but after time the pins slipped and it began to knock again. Keep in mind if you have a slipped liner you are anchoring the pin in an aluminum block which will eventually fail and leak oil.
I got "lucky" and my disco got totaled at the curb by a drunk driver right before I was going to top hat my sleeves. If you've pulled the motor you might as well go the extra step and fix it for good.
Old May 17, 2018 | 04:36 AM
  #147
Roman67's Avatar
@dakirkpa
If you use high temperature loctite on the screws buddy they'll never move or leak oil. Mine never have
Old May 17, 2018 | 07:01 AM
  #148
Sixpack577's Avatar
And lock wire them together, then they cannot back out.
Old May 18, 2018 | 04:44 AM
  #149
Roman67's Avatar
Good idea if you can, absolutely.
I never bothered on mine as drilling holes in the heads stainless steel socket head screws is a real pain in the ****
Old May 18, 2018 | 06:34 AM
  #150
Sixpack577's Avatar
Safety wiring them is in the original thread.
My Dad's a retired engineer, so he drilled all the bolt heads...which gave me the easy part, lol.
