i cant turn the key
i cant turn the key
i just got a 1995 discovery, it has this issue that when you put the key in the ignition to start it, you cant turn the key. You have to push it in and wiggle it back and forth until it decides to let you go. it's so frustrating. anyone have anyidea what this could be?
on
RE: i cant turn the key
Sure, your tumblers are dirty and may be warn out, quit playing with it. take it to a lock smith, have him remove the key, get your key code number from Rover and have a new one made.
If you are lucky and the tech can clean out your tumbler assembly you'll be OK, if not, go on line to Rover connection or DAP and buy a new tmbler assembly.
Mike
Mike
lowerrb
06-14-2013 07:25 AM
