Sponsored by: CARiD
Just purchased my first land rover! tons of trouble codes though :(
Old Sep 13, 2017 | 03:26 PM
mollusc's Avatar
Plugs will never spark if they are not grounded. That's how an electric circuit works.
It's also possible that your plug leads are bad. I would start by changing the plugs though, since they are so cheap.
Old Sep 13, 2017 | 04:19 PM
Plug wires are known to go on these.
After dark tonight use a spray bottle to wet down all the spark plug wires. Fire up your truck and enjoy the light show. Then tomorrow replace the wires unless there is no light show of course.
Old Sep 14, 2017 | 06:54 AM
WaltNYC's Avatar
Originally Posted by yesimbs
So spark plugs 5 and 3 may be bad. When they are screwed all the way in with the plug attached to them I'm still getting random Sparks coming off the bottom of the boot of the plug two spots on the Block. And when I have them unscrewed from the block but plugged in there only sparking if I'm grounding them out on another piece of metal close by.
Also cylinder 3 and 5 are reading at 90 PSI. I'm replacing the O2 sensors now
There is a pattern here.
Old Sep 14, 2017 | 08:24 AM
OH+D's Avatar
4wd High
Agreed on the pattern. Put the O2 sensors back on the shelf and sort out your spark and compression problem first. It's possible that those cylinders have been misfiring for so long that the cylinder walls or rings have been damaged or at least are dirty from the unburnt fuel.
Adam
Old Sep 15, 2017 | 04:40 PM
yesimbs's Avatar
so i replaced spark plugs number 3 and 5. number three actually had a crack in the ceramic part. I reset the ECU and it's it's running a lot smoother now. Still have the check engine light coming on that I'm going to have to go up to the shop to borrow their scanner to see what's going on. Thank you for the advice with getting the motor wet at night to see the Sparks
Old Sep 20, 2017 | 12:20 AM
yesimbs's Avatar
no more misfire codes!! Now im getting all new codes.
p0414 secondary air injection switching valve shorted
p0445 evap system purge shorted
p0448 evap emission system vent shorted
p0102 mass air flow low circuit
p0453 evap emission system pressure sensor high input
p0340 camshaft postion sensor A
P0134 O2 Sensor bank 1 sensor 1
p0154 o2 sensor no activitiy bank 2 sensor 1
p0135 o2 senor heater bank 1 sensor 1
p0155 o2 sensor heater circuit bank 2 sensor 1
p0141 o2 sensor heater circuit bank 1 sensor 2
p0161 o2 sensor heater circuit bank 2 sensor 2
which o2 sensors are which?
Old Sep 20, 2017 | 06:20 AM
mollusc's Avatar
Since all four of yours are throwing codes, that wouldn't seem to matter.
But the interwebs has the answer if you do a plain old search. O2 Sensor Identification and Locations - o2 sensors
Old Sep 20, 2017 | 08:24 AM
I'd be checking for a vacuum leak
Old Nov 3, 2017 | 11:50 AM
yesimbs's Avatar
I hate leaving threads open-ended so here are my results. I replace the front two O2 sensors and then went ahead and took an intake manifold off and did all my plugs and wires. I noticed one of the wires was pushed out of the plug on fuel injector number 8 so I put that back together as well. And BAM! Now she's running like a champ. I have one solid check engine light still on for the map sensor but other than that she's running so smooth
Old Nov 7, 2017 | 11:02 AM
Lisa Bunch's Avatar
You are on borrowed time with that blown head gasket.
LNScott
Mar 31, 2017 03:22 PM
lr3_ovrlnd3r
Mar 2, 2016 12:32 PM
grandkodiak
Apr 10, 2012 01:53 PM
B.Young
Mar 28, 2011 04:57 PM
tornado_735
Mar 28, 2009 05:34 PM
