Sponsored by: CARiD
LR3 front driver seat no paper
Old Nov 13, 2016 | 07:39 PM
richdw's Avatar
Default LR3 front driver seat no power
no power to front drivers seat. Power to passenger seat and mirrors. Check fuses again and again.
Started after moved seat up to get something that fell to the side of the set. Could get it back. Read many posts mostly regarding seat mirrors and heated seats. Tested motors all work switch works at all position. Ran out of ideas
Old Nov 15, 2016 | 08:43 PM
abran's Avatar
Check the multi plug connector at the front, under seat section. It has a 7mm bolt head that makes it connect. You may have severed a wire if it was not zip tied into the proper position.
Old Nov 21, 2016 | 07:09 AM
richdw's Avatar
Thank you for the tip, I check the seat using a 12v battery, all functions work .
Check power at multi block no power to main brown and green wire. Only power to one wire small red wire.
Is there a cross over power from passenger set to drivers seat ?
Thanks for any help
Alex_M
Dec 18, 2015 08:26 PM
js8488
Sights N Sounds
Dec 10, 2015 10:42 AM
JRover83
Sep 29, 2012 07:34 PM
jfall
Jul 23, 2012 04:32 PM
sorbet35
Feb 24, 2012 02:10 PM
