Sponsored by: CARiD
LR3 key fobs not working after replacing car battery
Old May 29, 2014 | 09:27 AM
LandoMN's Avatar
Default LR3 key fobs not working after replacing car battery
Hello I have a 2005 LR3 and recently replaced the car battery. This was an ordeal because Batteries Plus spec'd one that was too large and couldn't get the clamp on it. I had to drive to a different store across town to get one the right size. After replacing the car battery with one the right size my key fobs have stopped working. I have two sets and both won't respond to lock and unlock. I talked to the dealership and they say the issues are unrelated but the timing seems to think something happened with the receiver or programming.
Car runs fine but I have to manually lock and unlock which is really a pain. Any suggestions would be appreciated.
Old Oct 20, 2015 | 09:57 AM
pchak's Avatar
7th Gear
Default Same issue-replaced battery,FOB not working
I was surprised to find that no one had responded to this post. I figured that maybe a bump will attract some attention.
The battery in my 2008 LR3 died. I could not jump start it, but was able lock/unlock it in that state. I replaced the battery with a new one (battery was out overnight). When I put in the new battery, I found that the remote fob will not lock/unlock.
I drove the car 12 hours twice since then, so I'm pretty sure that the fob is charged.
I'm not ignoring the corrosion issue, but I'm pretty confident on the cause and effect of replacing the car battery.
Anbody come up with ideas on this?
Thanks!
Old Oct 20, 2015 | 01:32 PM
DavC's Avatar
Might need reprogramming? I pray you don't have to go to the dealer for it but I think only something like an IID tool can help you there..
Old Jul 2, 2024 | 04:36 PM
Beachcomber2's Avatar
Bumping this old thread.
My 2007 LR3 SE needed a battery replacement. I just put in the new battery, quick swap, took maybe 10 minutes. Now both my (previously working fine) key FOBs will not unlock or lock the truck.
Please help!!
umwolverine
May 31, 2024 06:51 AM
mollusc
Aug 28, 2023 03:43 PM
clina1@outlook.com
Feb 8, 2019 06:29 AM
DISCOENO
May 2, 2014 12:45 AM
SmooveB23
Nov 11, 2007 08:33 AM
