Sponsored by: CARiD
manual and sport dash lights.
Old Mar 28, 2012 | 02:56 PM
thebazzoid's Avatar
Default manual and sport dash lights.
Hi All. I am new here. Got a problem with 2003 disco 2. The warning lights on the dash, manual and sport, for the auto g/box flash after selecting reverse gear at the first start of the day. When i select Drive they still flash. If i turn the ignition off, and restart, all is ok for the rest of the day no matter how many times i stop and start the motor. Why only on the first startup does the problem occur, and after "rebooting" it is ok? I believe it could be a problem with the g/box switch and/or the associated harness. As a new switch is £339 + vat i would appreciate some help???
Old Mar 28, 2012 | 03:29 PM
ptschram's Avatar
Adjust the switch using park and neutral. It's likely just worn a little and you're perhaps putting it into park with more vigor than you think.
Old Mar 28, 2012 | 03:35 PM
thebazzoid's Avatar
Thanks PT. will have a go!!!!!!!!!
chavhater
Jul 28, 2021 05:57 PM
rogerrover
May 29, 2012 07:35 AM
dgm
Nov 20, 2010 05:39 PM
likenmori
May 30, 2008 10:01 PM
deang
Sep 7, 2007 09:48 AM
