Sponsored by: CARiD
Misfire after many changed parts !!!!!
Old Jul 26, 2015 | 04:45 PM
bergin90's Avatar
Default Misfire after many changed parts !!!!!
Hey guys,
I know this has been covered somewhere in this forum !! But my 03 disco started misfiring, code reader said it was all four (1-3-5-7) After reading about this problem here, problem seemed to point towards coil fail, so after replacing coil (new used) and new plugs and wires and than crank sensor problem is still there ??? Checked connection on coil pack and on spark plug boots still no joy. Is there a relay or a fuse in this system that I might check ? Only money I wanna spend right now is a plastic for sale sign !!!!
Old Jul 26, 2015 | 05:38 PM
First you never use a used coil.
Second, your message is confusing, you mention misfire and then jump into a crank sensor issue. Can you be a little more clear on your problem.
Old Jul 26, 2015 | 06:03 PM
Joemamma1954's Avatar
The culprit in my opinion is the coil. My son and I both had misfires on multiple cylinders on the same bank. I went the route, that may be frowned upon, I know most on here recommend buying only the OEM Bosch electronics, but I went to Advance Auto and purchased new coil for 65.00, since the intake had to be removed, I went ahead and purchased the Kingsborne 8mm wires. Result was no misfires for 6 months now. After that I did the same to my son's 04, and the same result. I am not saying this is your problem, but just relaying my experience. I agree with DiscoMike, there are some things I will not purchase used or rebuilt. Usually starters, alternators or coils. I have purchased rebuilt starters and alternators before with lifetime warranty, but after replacing said items over and over(under warranty), I decided to go with new whenever possible.
Old Jul 26, 2015 | 07:30 PM
bergin90's Avatar
Yea, now I think that the used coil pack might have been a bad move ($45) could have gone towards a new one !!! Will check with advanced auto in the am.
Disco Mike, just from reading here at this forum, with the problem I have after changing all parts and it's still missing, some say that it could be the crank sensor (was easy to change just a b#%$ to hook up cannon plug) but now I know better !!!
Thanks
Old Jul 27, 2015 | 07:03 AM
drowssap's Avatar
1-3-5-7 do not run off the same coil, so i dont see that as your problem
Old Aug 3, 2015 | 06:30 AM
Start by looking for a vacuum leak on the drivers side, your problem is not plug/wire or coil related.
abran
May 4, 2014 10:36 AM
Kinz384
May 15, 2013 08:11 AM
jasoncrew03
Nov 15, 2010 09:48 PM
herblatham
Jun 28, 2008 09:09 PM
phia@binoco.com
Dec 10, 2006 11:23 PM
