Sponsored by: CARiD
My lifters are noisy only when accelerating
Old Dec 24, 2015 | 09:11 AM
  #121
ihscouts's Avatar
Are you back home? (Hope so.) Have you checked the ignition system fuses this time?
Old Dec 24, 2015 | 09:33 AM
  #122
Roverfanatic's Avatar
No half way dropped off Blazer at sisters. Least not on side of road.
Yes on tested fuses.
She has run for the last year that I installed the fuel pressure gauge at 27 to 34. I put a replacement fuel pump in her about 2 years ago. Finishing up at salvage yard and will replace filter as soon as I return. Dont' think it's the issue but I have a new one so it can't hurt. been about 3k since a changed it
Old Dec 26, 2015 | 04:37 PM
  #123
Okay, not sure what this means but, here are the results:
Spark good at coil when cranking..
With key in position right before cranking position:
V1 = 13 volts
V2 = 12 volts
V3 = 12 volts
V4 = 0 volts
V2 and V3 are 11 volts over spec.
Not sure what to make of the chart on the PDF about it...ideas?
Old Dec 26, 2015 | 04:53 PM
  #124
ihscouts's Avatar
Your readings are perfect.
V1 More than 12 volts. (13)
V2 1 volt maximum below volts at V1. (12)
V3 1 volt maximum below volts at V1. (12)
V4 0 volt - 0.1 volt. (0)
Move on to test 3.
Old Dec 26, 2015 | 05:13 PM
  #125
Test 3:
"Connect voltmeter between battery positive (+ve)
terminal and H.T. coil negative (-ve) terminal.
Voltmeter should register 0 volts.
Switch ignition ’On’, voltmeter should still register 0"volts.
Mine is reading 12 volts with ignition on or off...
Old Dec 26, 2015 | 07:06 PM
  #126
ihscouts's Avatar
Have another coil handy?
Old Dec 26, 2015 | 07:14 PM
  #127
No.... but is that the issue??? I can have one here over night....I made the hugh mistake of not putting my parts container in the truck as I was worried about the weight. Stupid....
Old Dec 26, 2015 | 07:38 PM
  #128
ihscouts's Avatar
Think for a minute. Your meter is between battery positive and on the coil's negative lead and your getting 12V... that's a dead short to ground. It's supposed to be a dead circuit - (0V).
For future jaunts away from home, having a spare coil in the glovebox is a no option must have. I'm fairly sure you can grab a decent coil from any parts store. Anything from 20k to 35k Vdc should work.
Old Dec 26, 2015 | 09:41 PM
  #129
I'm assuming the positive and negative on the coil energize to activate the coil...I just don't get why the coil is creating spark when cranking when there is a dead short....anyway having my parts box overnight-ed to me so I will have a coil by Monday morning latest. Thanks for your help scouts....
Old Dec 27, 2015 | 08:19 AM
  #130
I would love to pick up a coil today...my parts box won't show up till end of day tomorrow. Is there a domestic crossover coil I can pickup and use? I realize you provided specs on a coil but, I think the local parts guys are not going to be able figure out which ones those are...maybe but I doubt it......
