Sponsored by: CARiD
My lifters are noisy only when accelerating
Old Nov 16, 2015 | 03:21 PM
  #31
Roverfanatic's Avatar
One sided conversation
Old Nov 16, 2015 | 03:30 PM
  #32
ihscouts's Avatar
Originally Posted by Roverfanatic
ihScout..is the lifter your talking about the third or fifth from the RIGHT? They both look round to me..
Third rocker down in your pic that ends with ..._470 .... cylinder #4
I didn't mean to freak out but I'm seeing things that need addressing.
Old Nov 16, 2015 | 03:31 PM
  #33
ihscouts's Avatar
If you landed a whale then it's time to invest in your Rover jalopy.....
Old Nov 16, 2015 | 06:51 PM
  #34
Seeing the inside of the engine made me realize it's time to rebuild. I just need to get through the next month or so before I start. Band-Aids for now....Taking the intake manifold off has not been my idea of fun today but at least I could get to the lifters I had 2 in standby for the last year or so. [new]
Old Nov 16, 2015 | 06:52 PM
  #35
With what I put in it already [Seafoam and Rislone] Do you think I should run engine flush as well before I change the oil?
Old Nov 16, 2015 | 07:26 PM
  #36
ihscouts's Avatar
Not really. You've already thinned the oil enough.
Old Nov 16, 2015 | 07:36 PM
  #37
ihscouts's Avatar
The engine serial number you gave me isn't enough characters, again it's right at the dipstick, hard to see if it's grime covered which is normal. What I'm looking for is a "B" at the end of the character string. Unless you know you have a distributor run oil pump or crank spun gear-rotor pump. It is a 3.9 correct?
Old Nov 16, 2015 | 08:09 PM
  #38
Okay Thanks...one last thing to do. Sorry for another question but, do you think I should drop the pan when I change the oil and clean it out? I was planning on it if I had ran that flush through it.
Old Nov 16, 2015 | 08:12 PM
  #39
TOM R's Avatar
I would clean in the heads and lifter valley best you can with a tooth brush or whatever and some chemical to remove sludge and loose burnt crap, then drain oil before you start the engine cause all that crap will end up in the oil pan, no need to change filter just my .02
Old Nov 16, 2015 | 08:33 PM
  #40
Well Scout got me pretty freaked out on filter contamination, so went and bought another mongo Mann 950 today. Not worth taking any more chances than I already am by driving it for 12 bucks.
Scout, I'll have to look in the daytime for the number, it's too dark in the garage I'm in to see it. I think it's a yes on the distributor but not 100%. It is a 3.9.
