Sponsored by: CARiD
No start... except with starting fluid.
Old May 24, 2018 | 07:19 AM
  #21
WaltNYC's Avatar
from the gems_obd.pdf (can be found in the link) pages 59-64 describe startup and CKP function. Also some flowcharts and tables there that might help illuminate.
3.7 Crankshaft and Camshaft Position Sensor
3.7.1 Description
1. Diagnostic Trouble Codes:
Crankshaft Position Sensor Circuit Malfunction P0335
Crankshaft Position Sensor Range/Performance P0336
Camshaft Position Sensor Circuit Malfunction P0340
2. Monitoring Procedure
Summary
Problems with the crankshaft and camshaft position sensors will be detected by cross - checking each sensor's output, identifying when one sensor is
operating and the other is not. A missing tooth check will test that all tooth edges are being correctly detected and that there is a missing tooth
present. As the crankshaft speed sensor is central to engine management system operation there is no default operation, which would allow the car to
run when there is a crankshaft position sensor circuit malfunction.
Crankshaft Position Sensor Check
If more than CRANK DIAG MAX CAM PULSES camshaft position sensor pulses are detected during CRANK DIAG MIN TEST TIME, while the engine
is in STALL, then a crankshaft position sensor fault is present.
When the engine enters CRANKING mode, implying the crankshaft position sensor is operational, there is no crankshaft position sensor circuit
malfunction present.
Camshaft Position Sensor Check
If CRANK DIAG MIN CRANK REVS crankshaft revolutions occur from exiting STALL conditions, without CAM SIGNAL VERIFIED being detected,
then there is a camshaft position sensor fault present. There is no fault present if CAM SIGNAL VERIFIED is detected on every engine revolution for
CRANK DIAG MIN ENG REVS.
Crankshaft Range / Performance Check
Missing teeth are expected to be NO OF TEETH ON WHEEL crankshaft teeth apart.
If the number of crankshaft position inaccurate fault event occurs then the fault event counter should be incremented by one, up to a limit of CRANK
DIAG FAULT LIMIT. Every time the tooth count equals the actual number of teeth between missing teeth then decrement the fault event counter by
one, down to a limit of zero.
If the fault event count reaches CRANK DIAG FAULT LIMIT then there is a crankshaft position inaccurate fault present. There is no fault present only
when the fault event counter reaches zero. The fault event counter is cleared to zero at the start of a trip.
3. Primary Detection Parameter
Crankshaft Position Sensor – Crankshaft Position sensor signal edges.
Camshaft Position Sensor – Camshaft Position sensor signal edges.
4. Fault Criteria Limits
General - presence or not of sensor edges.
The non-existence of at least 6 CRANK DIAG MAX CAM PULSES within the minimum CRANK DIAG MIN TEST TIME period of 9 seconds.
Indicating an average speed of 80 rpm.
The non-setting of the Camshaft Position signal verified flag within the limit of CRANK DIAG MIN CRANK REVS' 100 revolutions.
NO OF TEETH ON WHEEL constant is dependent upon the sensor wheel design (35 teeth), a fault is registered if the tooth count total between
missing teeth is out by one or more.
5. Monitoring Conditions
The crankshaft position sensor check will be run if the engine is in stall.
The camshaft position sensor check will be run if the engine has exited stall and battery voltage is greater than 8V.
The missing tooth position check will run when the engine is running.
6. Monitoring Time Length / Frequency of Checks
The camshaft position sensor check will be run if the engine has exited stall.
The missing tooth position check will be run once every engine revolution.
7. Criteria for Storing a Diagnostic Trouble Code
Two successive trips where the diagnostic routines indicate a failed crank or cam sensor.
8. Criteria for Illuminating MIL
9. Criteria for Determining Out of Range Input Signals
The crank / cam sensors produce non-linear outputs; the criteria will be signal/no signal.
I can't understand why you are not getting any codes. The CKP needs to be spaced properly in order to 'read' the reluctor tabs. Is your truck a manual transmission or automatic? And is that what it was originally? (IIRC the CKP are slightly different for each)
Old May 24, 2018 | 06:34 PM
  #22
Goldthumb's Avatar
Hi there. My truck is a automatic... and I ampretty sure it's always been that way. :-)... no signs of a swap.
Its my understanding that the CPS is working as it has spark while cranking... and of course it runs after I get it started. Does that sound right to you?... or could the CPS be "half working"?
Thank you for for all your help with this!
Old Apr 1, 2019 | 04:29 PM
  #23
kar1179's Avatar
4wd High
Hi Goldthumb - did you ever get this one figured out? I'm having the same issue. Was wondering if it could be the neutral/inhibitor switch?
Old Sep 3, 2021 | 11:53 AM
  #24
Maine57S1's Avatar
Bumping an old thread. Having the same issue with a NAS Defender. Any insight would be appreciated.
Old Sep 3, 2021 | 10:49 PM
  #25
kar1179's Avatar
4wd High
I never got mine figured out, kicked my rear. I actually ran a toggle to manually fire the injectors when the pump kicked on to get some fuel for it to fire on. After that runs like normal. If you figure it out, please share here.
sickws6
Oct 1, 2019 08:29 PM
Julreilly
Jun 17, 2018 04:19 PM
discoHUSS
Jul 24, 2013 04:27 PM
Brad S1
Jul 4, 2006 02:42 AM
devildogrover
Dec 24, 2004 04:48 AM
