Sponsored by: CARiD
oil leak
Old Sep 9, 2011 | 04:10 AM
Banning's Avatar
4th Gear
Default oil leak
I have just purchased a 1995 land rover discovery v8i and have found an oil leak coming from above the oil filter i found one from the oil pressure switch so i replaced that then found another one from what appears to be a welsh plug just above the oil filter is it actually a welsh plug if not whats required to repair it well i think its a welsh plug its round and its set in from its sourround a bit
Last edited by Banning; Sep 9, 2011 at 04:14 AM. Reason: not enough infomation given
Old Sep 9, 2011 | 04:51 AM
see post https://landroverforums.com/forum/di...-instal-43603/ for pix of what is involved around the front cover seal, also download the free RAVE set of tech manuals if you don't have them, see below for link.
Old Sep 9, 2011 | 05:45 AM
Banning's Avatar
4th Gear
Default front cover spring
it would appear that the leak is coming from the bung where the oil pump spring is any ideas how to repair and that for that advice and link much appriechated
Old Sep 9, 2011 | 06:57 AM
The RAVE manual should have clear drawings and write up on it. Note that other members have posted that they had success on small leaks with the White Shepard Oil Leak product where gaskets are involved. Many Rover things are sealed with hylomar (spelling?) similar to RTV.
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
