Sponsored by: CARiD
Oil Pan Gasket.
Old Sep 26, 2011 | 05:06 PM
chaz614's Avatar
Question Oil Pan Gasket.
Hello All,
I recently Purchased a USED 1999 R.R. 4.0. I discovered it has an oil leak which appears to be coming from the front of the oil pan area. I'm no Mechanic by any means, but assume its just a bad gasket?? I have replaced gaskets before, is this as easy on a RR? Meaning: Darin Oil, drop pan replace gasket, mount pan back, fill engine with oil, and done?...
Old Sep 26, 2011 | 09:18 PM
Yup, pretty much that simple.
Here is a tip, support the truck by its frame and let the front axle hang down as far as it can.
Old Sep 26, 2011 | 09:23 PM
And be sure to clean around and inspect the front crankshaft seal, which is just in front of that oil pan, and can throw oil for some distance when leaking. Both my front seal and pan gasket are on the to-do list.
Old Aug 5, 2012 | 11:04 PM
eitydeuce's Avatar
Yo Savannah Buzz, how hard is it to change out the front seal?
Old Aug 6, 2012 | 08:35 AM
drowssap's Avatar
take of the belt remove the front pully, pry out the old one drive in the new one.
mike111
Jun 2, 2014 08:58 AM
jpmiller
Sep 26, 2012 06:32 AM
afphinfan
Jan 5, 2008 11:04 AM
91rover
Jun 13, 2007 03:15 PM
modelwerks
Oct 13, 2005 05:39 AM
