Sponsored by: CARiD
Oil sensor casting split, TD5
Old Jul 1, 2021 | 12:44 PM
titpygmy's Avatar
Default Oil sensor casting split, TD5
I have a damaged thread, possible crack in the senior switch casting on my TD5 Defender. Is this much of a job to change out the oil cooler? I think it is just turbo out, oil filter housing off, centrifugal filter housing off, then oil cooler. Any drama to anticipate?
Old Aug 6, 2021 | 02:51 PM
bidoulatt's Avatar
Banned
IMO the Td5 is the best engine the Defender ever had. The biggest problem, especially on early ones, is the engine wire harness pulling oil and thus causing shorts. I had that problem on my ‘05, and it lead to it sometimes running on only 3 cylinders. If found early it’s an easy fix, if found to late the 192.168.100.1 192.168.1.1 main harness and the ECU are gone too.
titpygmy
Defender
Jun 30, 2021 07:33 AM
ljdiscovery
Dec 2, 2020 12:42 PM
timbont
LR4
Jun 12, 2019 02:14 PM
Rovermike85
Aug 29, 2011 03:47 AM
Camelman
Sep 2, 2008 01:18 PM
