Oil in coolant, TDV6, oil cooler?
Old Jun 10, 2019 | 09:12 PM
timbont's Avatar
Default Oil in coolant, TDV6, oil cooler?
Hi, I have a D4 2010 TDV6 3.0 litre. I have noticed that I have engine oil in my coolant overflow bottle but no water in the oil or overpressure in the coolant system and since changing my oil filer an oil leak from the top of the engine running down the right side. I have recharged the filter and seal but still leaks slightly. I am leaning towards the oil filter housing, oil cooler. My questions are is it most likely that the oil filter housing / cooler is the problem and can the oil cooler housing be overhauled with new seals and gasket as I’m in Australia and postage from the UK is more that the second hand unit. Has anyone had success in cleaning out the oil from system and coolant bottle as it was replaced last year as the float sunk and I don’t want to replace it again. I am a retired Toyota car mechanic. I have completed the following in the last two years. Thermostat housing, replaced front disc rotors, replaced front timing belt, no specialised tools needed, just 2 x 6mm pin punches, turbo oil drain modification and cleaned out throttle body, flushed ZF 6 speed automatic using Penrite ATF BMV. Thanks for any feedback.
Old Jun 12, 2019 | 02:14 PM
abran's Avatar
Sorry, no experience with that. We don't have that motor here in the US.
ljdiscovery
Dec 2, 2020 12:42 PM
Zulu1
Apr 16, 2019 03:01 PM
Rufflyer
Mar 22, 2015 10:13 AM
Rovermike85
Aug 29, 2011 03:47 AM
tbesselman
Feb 4, 2010 06:54 AM
