Sponsored by: CARiD
our first landy disco
Old Aug 13, 2013 | 06:15 AM
MINTY's Avatar
Default our first landy disco
Hi All
im new to landrovers and have no clue where to start so here goes
first of all i seem to have the lighting sockets at the back of the headlights burnt out, on both lights, this happened rather rapidly when i switched them on
its the black wire on both
any idea
also the rear side light dont work, i checked all bulbs and fine, could this be linked
the motor is a 3.9 v8, during our trip home from where we bought it, (roughly 2hr drive)
the expansion tank used up 2 3rds of the water, i freaked thinking that it was the head gaskets but i noticed a small amount of water on the floor below the rad on r.h.s but after i filled the tank no leak, any thoughts?
gonna book it in to have a once over
what are the tell tail signs of head gasket going?
cheers
minty
Old Aug 13, 2013 | 07:30 AM
What year is the truck, how many miles on it and how mechanical are you?
Go a coolant pressure test to find the leak and consider doing my service list for D1's
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
6 Qts. Of Vavoline’s high mileage Dextron 3 ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of Vavoline’s DOT 4 Brake fluid
4 Qts of synthetic ATF fluid
1 bottle of Lucas P/S stop leak
1 bottle Lucas Tranny Stop Leak
2 Gallons of Peak or any green or yellow coolant, don’t use Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
1 new fuel filter
Hoses and belts, as necessary
Front and rear wheel bearings and all seals for wheel bearings and swivels if necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive, change the filter if necessary
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Repack or replace the 4 wheel bearings
Service the swivel *****, reseal, refill and adjust the pre-load
Replace the fuel filter
Inspect and replace all hoses, brake, coolant and cooler lines as necessary
JKPinPDX
May 23, 2012 07:17 PM
Christina Jon Harrington
Jan 28, 2012 09:17 PM
Jan 20, 2012 03:03 PM
JumPeR04
Mar 3, 2009 12:11 AM
unstable
May 20, 2008 07:45 PM
