Sponsored by: CARiD
Putting a 99 disco 2 engine in an 02
Old Mar 4, 2018 | 09:01 AM
mrod3263's Avatar
Default Putting a 99 disco 2 engine in an 02
Ok guys so quick question.
Due to a cracked block I’ve decided to swap out engines.
They are selling me one from a 99 with secondary injection with only 90k
mine in a 2002 vin 5 with secondary injection.
just wondering if there will be any differences before I pull the trigger?
Old Mar 4, 2018 | 05:41 PM
mollusc's Avatar
What is "vin 5"?
Old Mar 4, 2018 | 06:58 PM
mrod3263's Avatar
Default They told me that was the engine code
Originally Posted by mollusc
What is "vin 5"?
They told me hat was the engine code
4.0 with secondary air injection
Old Mar 5, 2018 | 06:23 AM
mollusc's Avatar
There are lots of threads on here about engine swaps. As far as I have read, the blocks should be the same so there should be no problems. The SAI/Non-SAI heads are different, but both your old and new engines have that so there should be no issues there either.
Old Mar 5, 2018 | 10:13 PM
No Doubt's Avatar
Make certain that they are including the 4.0's ECU *and* BCU because 4.0 is not 4.6. Your engine mapping from your 4.6 shouldn't match that 4.0 motor so you'll need the 4.0's ECU & BCU.
notny41
Apr 2, 2021 11:36 AM
Jeff Blake
Dec 3, 2016 07:46 PM
captain1976
May 16, 2016 07:18 AM
Gordon Bombay
Feb 25, 2010 09:46 PM
smokey73
Feb 19, 2010 07:04 PM
