Sponsored by: CARiD
Range Rover ABS
Old May 10, 2006 | 08:10 AM
bhonkers's Avatar
Default Range Rover ABS
My 3.9 Vogue (1991) has a mystery fault. The ABS system pumps all brakes on firmly. After about 30 mins standing the pressure releases ok until the brake is applied again. Good pedal, master cylinder ok. Pipes, calipers etc ok. all checked through.
Any hint would be appreciated before I call The Samaritans!
Best wishes to you all.
Bob
Old May 10, 2006 | 11:17 AM
Default RE: Range Rover ABS
Sounds like a failing brake accumlator. When they start to fail, they hold little or no pressure in reserve.
Mike
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
