Sponsored by: CARiD
range rover cyl 2.4,6,8 problem
Old Feb 10, 2008 | 05:13 PM
pedrom's Avatar
Default range rover cyl 2.4,6,8 problem
Hi if somebody can't help me. I have a 1990 range rovercounty 3.9. I bought it with cyl #7 deadno compression,took the heads out and #7 had intake valve seat pulled out and no damage to piston. Then I send the heads to be repaired at the machine shop.Then i put new timing chain and sprokets with the repaired heads and gaskets. I start using the rover but it lacks of power ,i check the compression again and i have more than 155 psi in every cyl. But i found spark plugs 2,4,6,8 clean and i mean white compared to 1,3,5,7 that have a nice brownish color, the thing is if i touch the exhaust manifold from 2,4,6,8 side is cold to the touch compared to the other side manifold that wiil burn your hand right away. Today i try swapping both o2 sensors nothing change ,a friend told me that if right catalitic converter is clogged it could be my problem. Another thing is that i try pulling out fuel injector plugs from 2,4,6,8 and nothing happened but when i pulled 1,3,5,7 the engine start misfiring. Sorry to be this long but i ran out of troubleshooting ideas!
Old Feb 10, 2008 | 06:17 PM
Default RE: range rover cyl 2.4,6,8 problem
Sounds like you may have a coolant leak on the right bank.
Might want to do a pressure test on the coolant system.
kward12
Jan 8, 2013 10:15 AM
Jman67
Feb 15, 2009 05:07 PM
rcm
Nov 5, 2006 10:27 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
tbesselman
Jun 1, 2005 01:54 PM
