Re-torquing heads ?
Re-torquing heads ?
Hi all.
Removing left hand head to replace its gasket with a small leak from coolant passage into #7 combustion chamber, noticed that some outer head bolts were not tight as the central ones.
Could that have caused the failure ?
The manual does not give torque figures but could be 'sensed' with a torque wrench after installing per the service manual 180 degrees instructions.
If a torque figure is found as reference that way, should the still healthy right hand be retorqued to prevent gasket failure, and/or do the re-torquing on the newly fixed after a number of miles?
At the machine shop, warping was not detected per the manual inspection procedure, but showed 0.003" warping across #7 and the coolant passage. Such location/direction is not under the check lines per the manual. Watch out !
JBEGIN
06-27-2009 12:38 PM
