rough in morning
lately my 98 disco runs rough for about 2 mins... it seems to be missing. after about 2 mins it suddenly starts running smooth. i can park it for a few hours and start it and it still runs great.
Any suggestions for the most likely culprit?
Hmmm, get a tune up? [sm=joke.gif]
Could be many things.
When the temperature of the coolant is low, or cooler then slightly warm, the ecu will go into cold start enrichment mode and do it's crank rotation count while enabling the fast idle controller and fuel enrichment (wider pulse width for the injectors). I don't know about two minutes, but this usually takes less than 25 seconds for it to idle down, unless it's REALLY cold. So, the culprit may be a soiled fast idle control valve, or possibly a defective temperature sensor throwing the ecu into default mode since it can't make proper calculations to control the amount of air it bypasses for idle speed.
Maybe your issue relates to this? ---> https://landroverforums.com/m_8367/tm.htm
dillhole
Feb 20, 2020 02:30 PM
disco12
Feb 19, 2006 03:24 AM
