Sponsored by: CARiD
Service Engine Soon light
Old Dec 9, 2008 | 07:48 PM
mr_boondoggle's Avatar
Default Service Engine Soon light
2003 Freelander: The Service Engine Soon light illuminated. Using an Actron Scanner, I got codes 1470 and 1472 so I replaced both Varible Intake Butterfly valves, aka motor 1 and motor 2. Then cleared the fault code. The Service Engine light returned. Now the codes are 0172 and 0175. There is a difference between my Rave Service Manual and what I get from my internet research. Two web sites say trouble faults P0172 and P0175 indicate a rich reading from both O2 sensors. My Rave manual says, "fueling odd bank (LH clyinders rich limit" and "fueling even bank (RH cylinders) rich limit. My thought is to swap both O2 sensors and clear the fault code.
What do you think? What should I do?
Old Dec 10, 2008 | 10:15 AM
Default RE: Service Engine Soon light
Those codes indicate that both ot your banks are running rich. How many miles on your Rover?
Need to start looking for vacuum leaks, maybe a MAF, starting to fail.
Old Dec 10, 2008 | 11:37 AM
Thank you for the reply. What is a MAF? What does it look like and where is it located. My '03 Freelander has 92816 miles.
Under the noise suppression cover (on top of the engine) are a few rigid plastic hoses that cross over the top of the intake manifold.
The tee that connects them broke and I put it back together as best I could without replacing the Tee. Is that my problem?
Does the Actron obd II scanner work properly on a Land Rover Freelander?
Old Dec 26, 2008 | 02:32 AM
rinmud's Avatar
The motors you replaced are called vis motors. They failed becuase the upper intake is falling apart causing havoc in the variable manifold and setting off up to 6 codes. The motors never fix it becuase the valves they are moving are either jammed, broken or soo loose that sometimes sounds like a valve tap scottt
Old Dec 26, 2008 | 12:48 PM
The MAF is usually located between the air filter and the t/body.
Don't got throwing parts at it though till some confirms the cause of this issue.
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
jerrytrancik
Jan 9, 2008 05:52 PM
jerrytrancik
Dec 9, 2005 03:04 PM
Woody Reems
Nov 29, 2005 06:08 PM
rinmud
Oct 1, 2005 04:32 PM
