Sponsored by: CARiD
service help
Old Feb 27, 2013 | 09:28 AM
HoopGuy's Avatar
3rd Gear
Default service help
Hi..newbie here. I understand message boards so I might be expecting too much here being it my first post but I do need some help.
2008 LR3 90k miles.
I need some work done and am trying to prioritize the list and wanted to get some feedback. This is what has been recommended with pricing.
Front Lower Control Arms $1271
Left Front Hub Assembly $658
Both Inner Tie Rod Ends $346
Rear Sway Bar Bushings $355
Wheel Alignment $169
Power Steering Fluid exchange $160
Brake Fluid Exchange $160
Battery Service $40
Fuel Injuection Service $189
Drive Belts $310
If anyone can suggest what is critical on this list..what should be done soon and what can be put off a bit..I am looking for some help.
Thanks!
Old Feb 27, 2013 | 10:43 AM
Rovin4life's Avatar
2008 LR3 90k miles.
Battery Service $40
Drive Belts $310
Thanks!
Left Front Hub Assembly $658 first or else everything else will fail. Do yourself a favor and buy the damn thing from atlantic british for pennies on the dollar and have it installed somewhere else. Its really easy to replace.
Battery Service $40
Do do any of this. especially the battery service. God thats so overpriced, its just they spray some anticorrosion on the battery, hell I would do it for free all the time, clean the battery and spray it down with water and then just spray a can of battery protectant.
the brake fluid exchange isn't bad but look around for cheaper places. you just open the bleeders and pump the brake. you just need dot 4.
The lower control arms and the inner tie rods should be done together and with the alignment. But the time is way high.
Where do you live? What is the shop rate?
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
Speed racer
Oct 11, 2008 10:56 PM
hollis
Oct 10, 2007 04:24 PM
