Sponsored by: CARiD
Strange Problem with 00 LR Discovery
Old May 24, 2012 | 10:17 AM
swoseth's Avatar
Default Strange Problem with 00 LR Discovery
I've got a strange question about a 2000 Discovery with the 4 liter,
Is it common for a discovery with this motor, to seep oil and coolant from the head gasket without blowing the gasket
Old May 24, 2012 | 10:21 AM
You can certainly have an external leak. Can it be solved by re-torque? Most likely not. If head gasket was replaced by previous owner, he may have done a quick fix and not had the heads machined back to spec. Are you sure it is coming from the head and not the valley pan gasket?
Old May 24, 2012 | 04:04 PM
swoseth's Avatar
i dont know, this is what i was told by the dealer, i was wondering if it was a common thing for it to seep like a dodge neon.
Old May 24, 2012 | 06:27 PM
No it is not common nor to be ignored. Coolant leaks usually get larger.
ctsigler
May 6, 2015 02:56 PM
yoda9999
May 23, 2008 11:11 PM
Camdisco24
Aug 16, 2007 05:49 PM
ranger
Nov 27, 2006 05:44 PM
dfarnham
Sep 3, 2006 09:54 AM
