Sponsored by: CARiD
Stuck in third gear
Old Aug 14, 2012 | 05:06 PM
Sounds like you are in limp mode, do you have a check engine light on, if so what are the fault code numbers.
Old Aug 14, 2012 | 05:13 PM
addeible's Avatar
Haha how true...this is eveyones chance to laugh at me.
Old Aug 14, 2012 | 05:15 PM
addeible's Avatar
What can I say, both my heart and my head want a lifted rover with 35s and the whole bit...but my wallet doesn't. Anyway I have yet to pull out the xyz sensor and the tranny cpu but I'll report back asap. Thanks again guys.
Old Aug 15, 2012 | 05:01 PM
addeible's Avatar
It is throwing a 0600 code for a serial communication link which I believe confirms the idea that it may be either the CPU or the transmission ECU. I have to put my transmission back together before it makes sense to start pulling out the computer so I'll work on that first. Thanks for the help and let me know if that code tells me anything for sure.
Old Aug 16, 2012 | 09:54 AM
hilltoppersx's Avatar
that isnt all that deep to be honest.
this is how deep i was when the tranny ecu got soaked.
Old Aug 20, 2012 | 04:59 PM
addeible's Avatar
Well im glad to say that after pulling apart the xyz switch and doing a transmission flush with new filter, the disco seems to be running just as well as before. Thanks so much for all the help guys!!
Old Dec 30, 2013 | 01:38 PM
Nathan King's Avatar
Quoted text:
did you get water in the truck? did you check the battery connections? again, you are in limp. my 3 bets are the connections at the battery, the xyz switch or the transmission ecu under the driver seat.
hilltopppersx,
What you describe above is exactly what happened to me and now I am stuck in 3rd gear. The Green "M inside the Gear" light is on and my gear selector doesn;t show what gear I'm in. What plan of action do you suggest? I already checked the battery connections.
ImQuattro
May 1, 2014 08:36 PM
Lee1140
Dec 1, 2009 10:17 AM
crainface
Feb 14, 2007 01:33 PM
stuttman
Nov 6, 2006 09:39 PM
ctinkler
Apr 6, 2006 03:24 PM
