Sponsored by: CARiD
Sun roof drain tubes
Old Mar 26, 2010 | 09:45 AM
Spensive's Avatar
Default Sun roof drain tubes
I need some specifics on the location of the front and rear sun roof drain tube exit points, it has been raining in Southeastern Pa for freakin days and I am tired of swimming inside my truck. I have a chance to work on this problem this weekend but need some details, I found the info on the rear tube coming out behind the tail light. Please somebody, keep me from drowning. Thanks
Old Mar 26, 2010 | 10:38 AM
hilltoppersx's Avatar
it may be at the exit points but it could be at the top near the sunroofs. people usually clean them out when redoing the headliner board. the fronts run down the A pillar and out the corners near the bonnet.
Old Mar 26, 2010 | 06:16 PM
jzhoward's Avatar
Are you getting leaks in the upper corners of your headliner? I had the same issue and the dealer had to drop the headliner and seal a "body seam leak". If not, disregard this message!
Old Mar 26, 2010 | 07:30 PM
WTF is a body seam leak? if leaks where the tubes connect to the sunroof. it will leak either cuz they are clogged there or clogged at the exit points.
Old Mar 27, 2010 | 09:59 AM
jzhoward's Avatar
Don't know. Apparently, It's an the actual weld where the roof meets the rest of the body? Thats what I was told when I had mine repaired. It was due to a faulty sunroof tray. I didn't do the work, nor see the work being done. I can just go off what they told me. Ask your local LR dealer...
Old Mar 27, 2010 | 10:01 AM
Rovin4life's Avatar
We have a fix for the crack, you break the thing and put in a smaller tube but seal the tube up with epoxy.
Old Mar 27, 2010 | 12:54 PM
Spensive's Avatar
Default thanks
Thanks guys, gonna do this in conjunction with the headliner
willstevens
Oct 6, 2022 07:41 AM
DiscoNoisebox
Jul 15, 2022 10:15 PM
bullhead
Jan 19, 2013 02:49 PM
mlelah
Freelander
Dec 23, 2012 12:17 PM
S4poor
Jan 3, 2008 02:12 PM
