Suspension Fault Alarms When Headlights Turned On
I have a 2005 LR3 and each time I turn the headlights on there are a number of alarms that light up, the suspension drops, and I am unable to change into 4x4 mode.
As soon as I turn the car and the lights off all the faults clear and the car works fine until I turn the headlights back on. Any ideas?
Easy things you could check (but probably won't fix it unless you get lucky):
Any Fuses blown?
Does it set codes?
Check wiring harness(es) for chaffing/shorts. I think there is headlight wiring behind the bulb/housing is prone to rubbing against the body and causing a short (but that results usually just a blown fuse). Do a search on the LR3 subforum.
Electrical gremlins are the worst kind. At least you can recreate the problem; if/when you take it to a competent Rover mechanic (dealer/indy) you'll want to demo the process in detail to trigger the fault.
Good luck!
kbarker27
10-13-2023 04:03 PM
Arth111
02-26-2022 06:28 AM
06Range
05-08-2013 09:01 PM
Street Wolf
09-27-2008 08:58 AM
