Sponsored by: CARiD
Suspension Fault Alarms When Headlights Turned On
Old Sep 26, 2012 | 07:58 AM
Larry Wright's Avatar
Default Suspension Fault Alarms When Headlights Turned On
I have a 2005 LR3 and each time I turn the headlights on there are a number of alarms that light up, the suspension drops, and I am unable to change into 4x4 mode.
As soon as I turn the car and the lights off all the faults clear and the car works fine until I turn the headlights back on. Any ideas?
Old Sep 26, 2012 | 09:40 AM
So, how mechanical are you, if not, find a good electrical Rover mechanic cause this is something you won't be able to fix.
Old Sep 26, 2012 | 12:37 PM
ghengis86's Avatar
Lol! (he's right, you know)
Easy things you could check (but probably won't fix it unless you get lucky):
Any Fuses blown?
Does it set codes?
Check wiring harness(es) for chaffing/shorts. I think there is headlight wiring behind the bulb/housing is prone to rubbing against the body and causing a short (but that results usually just a blown fuse). Do a search on the LR3 subforum.
Electrical gremlins are the worst kind. At least you can recreate the problem; if/when you take it to a competent Rover mechanic (dealer/indy) you'll want to demo the process in detail to trigger the fault.
Good luck!
Old Sep 26, 2012 | 12:40 PM
ghengis86's Avatar
Also, are there any messages displayed when it happens? And what icons light up?
Old Sep 27, 2012 | 08:02 PM
Rovin4life's Avatar
Does it have HID lights as factory standard? They need the air suspension to work in order for the HID lights to function correctly? They will throw a code for the lighting system along with the Suspension lights.
Old Mar 18, 2022 | 02:09 AM
Urbanart21's Avatar
Did you ever find the problem I'm having this same issue on my 08 lr3.
06Range
May 8, 2013 09:01 PM
anhernandez
Aug 18, 2009 12:47 AM
Street Wolf
Sep 27, 2008 08:58 AM
