"Suspension Fault" Light
Well it finally happened. After five virtually trouble free years of ownership, and the warranty expired, the "Suspension Fault" Light came on last week. I brought my 2006 LR3 to the local dealer. One hour and $1,120.00 later, the air suspension compressor was replaced. All is "good as new"
Except for my checkbook....
One interesting note, I watched the mechanic replace the compressor and it seemed rather easy. Three bolts, one wire, and a couple of hoses and the old one was out and the new one in (less than an hour). I went back to my office, did a little research online, and found the part brand new for under $600.00. Hmmm
I think IF there is a next time, I may be doing this myself...
Good Points
Does that make any difference?
thats the intake valve opening up. Unless it was loud compressor action then its possible it only needed a drier. But if you live in salt country its not a bad idea to replace the compressor because the salt gets into all of the compressor and rots alot of stuff. It is a LR3/SPORT right. if its a full size range rover then they just need the drier and thats all.
kbarker27
10-13-2023 04:03 PM
Arth111
02-26-2022 06:28 AM
06Range
05-08-2013 09:01 PM
