Sponsored by: CARiD
Thermostat Won't Open - 2001 Discovery 2
Old Oct 18, 2012 | 04:09 PM
ccars17's Avatar
Default Thermostat Won't Open - 2001 Discovery 2
There's a 2001 Discovery 2 where the thermostat won't open. Multiple new t-stats have been installed, from several suppliers, but none of them will open. Even putting the old one back on won't work. The AutoLogic scanner isn't picking up anything, and the Land Rover phone tech isn't available today. The water pump is working, and nothing is wrong with the radiator. It being air locked was suspected, but isn't the case. Any idea on what's going on?
Old Oct 18, 2012 | 04:25 PM
Rovin4life's Avatar
Do you have heat, is it overheating, What is it doing besides not opening up?
Old Oct 18, 2012 | 04:28 PM
Racer X's Avatar
Hoses hooked up backwards?
The upper hose assembly goes to the vertical port on the thermostat, the hose to the water pump outlet and recovery bottle goes to the angled port on the thermostat.
Old Oct 18, 2012 | 07:12 PM
It is not the t/stats, you have to have done something wrong.
How do you know they are not opening, have you checked the temp with a scanner, are you sure you didn't switch the hoses
Old Oct 18, 2012 | 08:56 PM
Bottom port on stat goes to lower radiator outlet. Upper center line port on stat goes to "T" fitting. Upper "Side arm" port on stat goes to water pump. What temps do you get with OBDII scanner?
Daniel Bøe
Freelander
Oct 13, 2014 12:41 PM
mazinqureshi@tiscali.co.uk
Jul 7, 2009 07:51 AM
rjmaype
Jan 21, 2008 11:49 PM
saltyrover
Feb 20, 2006 04:39 PM
