Sponsored by: CARiD
Ticking noise 2010 Range Rover
Old Nov 20, 2016 | 02:38 PM
Bullitt1067's Avatar
Default Ticking noise 2010 Range Rover
Hello,
Just registered to the forum and it's my first post. Hope you guys can help me out.
I just picked up a 2010 Range Rover full size 5.0 luxury edition with 45k miles. About a week ago I noticed a ticking noise in the cabin. The ticking speeds up with the RPMs in drive and in neutral. I was told it was the injectors since it's direct injected they are much louder. I went through the engine with a stethoscope and everything sounds normal and with the windows down you can't hear it at all. . I have a 2011 Jaguar XF with the same motor and I don't get this ticking noise. is this something that is normal to this model/engine ?
Thanks!
Leo
Old Nov 21, 2016 | 08:30 AM
chubbs878's Avatar
a "ticking" sound is never normal. People try to pass it off as the norm' because they are either too lazy or too incompetent to track-down the offending unit, OR they have not thrown enough parts at it. As you said, you have the exact same engine in another vehicle with no noise, so stick with your gut.
I hope that someone else who has successfully fixed the issue you speak of will find your post. I would suggest also posting on RRForums but I boycott those a$$holz.
Old Nov 22, 2016 | 05:56 PM
abran's Avatar
There have been reports of the cam that drives the high pressure fuel pumps on the bottom of the motor, I believe drivers side can cause a ticking noise. Try your stethoscope in that area.
Old Nov 23, 2016 | 07:40 PM
Thank you for the replies. Ill check it out. Have a great Thanksgiving
adawgum
Oct 25, 2016 06:55 AM
adawgum
LR2
Oct 21, 2016 08:47 PM
Humdinger
Oct 18, 2016 05:05 PM
lowndes
Oct 30, 2015 08:14 AM
john65b
Oct 10, 2013 05:00 PM
