Sponsored by: CARiD
TRANNY ISSUES or ELECTRICAL? need help!
Old Sep 23, 2008 | 10:07 PM
MoNtErover's Avatar
7th Gear
Default TRANNY ISSUES or ELECTRICAL? need help!
I went to get my battery tested today and it turned out to be bad. But it was less than a year old? Regardless, they replaced it and it seemed to once again give it better power when starting. But iit still has a weak idle and stalls whenever I apply gas. I drove it around my block and it stalled everytime I came to a stop. I opened the hood and made sure every electrical connection that I could see was tight. I pushed the fuel cut off button. I also found a sort adjustment **** for idle and turned it up slightly. It now stays running while driving and stopping (still somewhat unstable idle). Here's the crazy part. It now seems that it stays in 1st gear! I even tried starting out in first and manually shifting through them. I noticed a couple small hoses leading no where. One of them was coming from what I think is the choke. Could it be a vacuum line issue? Could it be something electrical? All I know is I have no clue! Also, this disco is for sale if any of you die hards are interested. Thanks for reading
Old Sep 24, 2008 | 08:08 AM
Default RE: TRANNY ISSUES or ELECTRICAL? need help!
You need to get your truck to a mechanic who can correct your leaks and deal with the idle, be it a bad IAC or what ever.
Bryan H
May 12, 2013 03:38 PM
DiscoByrd
Apr 7, 2013 08:40 PM
wrongway1
Aug 30, 2012 11:56 AM
tornado_735
Mar 17, 2009 12:59 PM
Bene
Jul 10, 2005 09:42 PM
