Sponsored by: CARiD
Transmission Problem
Old Sep 16, 2007 | 04:41 PM
kevinfunston's Avatar
7th Gear
Default Transmission Problem
I have a 1999 Land Rover Discover II. It has an alarm that come on when starting to drive. The transmission light comes on and blinks at the same time. It feels like it is not fully in gear. Also, I got under and listened to the tranny while in park and running, and there is a slight knocking noise. Any ideas what this may be?
Old Sep 16, 2007 | 04:55 PM
Default RE: Transmission Problem
Don't drive it, have it flat bedded to your local Tranny shop before you start it again, sounds like you have had a mechanical failure. If it is the tranny, yell if you want a price on a good guaranted used one.
Old Sep 16, 2007 | 08:09 PM
7th Gear
Ya, could you give me a quote on one? Thanks.
Old Sep 16, 2007 | 08:48 PM
dirtyduk's Avatar
Could that be a tranferbox light (beeping) alarm ? did you try shifting the T-Box leaver from high to low and back to high ?
If you have a tough time moving the leaver , move the trans leaver from D to N ,then move the t-box leaver.
The knocking might be unrelated ?
Old Sep 17, 2007 | 10:14 AM
7th Gear
Ya, I think that's the (transferbox)light/alarm.I tried moving it back and forth (and it was hard in both N and D), but I still get the alarm.
Old Sep 17, 2007 | 01:53 PM
You might want to give me a call so I can get some more ifo and maybe then be able to point you in a direction.
303-862-7680
Colorado 7 am to 8 pm
Tanrover
Dec 6, 2006 01:15 AM
cterrebonne
Oct 4, 2006 08:05 PM
MCA
Oct 4, 2006 01:45 PM
Grtis1
Aug 7, 2006 03:32 PM
basquiat
Jun 8, 2005 12:17 AM
