Sponsored by: CARiD
U joints issues
Old Jan 4, 2006 | 08:05 PM
klunkerchuncker's Avatar
Default U joints issues
Can anyone explain why the u joints on a 2000 Discovery are not serviceable and require replacement of the front drive shaft?
Old Jan 4, 2006 | 08:45 PM
05LandRover's Avatar
Default RE: U joints issues
so that land rover and dealerships can make money???
they don't want you to turn the wrench on your own vehicle, just like how a sealed transmission from ASTON MARTIN that is in the new jags and rovers costs 6 or 7 thousand dollars and can't be fixed but replaced, (as i understand, i might be wrong)
Old Jan 4, 2006 | 10:24 PM
mikemeyer0's Avatar
the only thing that makes the stock driveshaft "non-serviceable" is the non-greasble ujoints. go to napa, buy 3 new greaseable ujoints ~60, put them in if you know how to work with a double cardon driveshaft that has a centering pin.
Old Jan 4, 2006 | 10:28 PM
Bait's Avatar
I've seen one front DII drive shaft that was rebuilt by an Indy. It's a double cardon type joint. No idea on how they did it.
05', It's just not economically feasible for the Manufacturer to provide training, tools, and parts to rebuild transmissions in the Field for such a low volume vehicle line. Look for that to change as Ford already has Ford transmissions in Jag's.
Old Jan 10, 2006 | 05:05 PM
MadBilly's Avatar
Just go to a drive shaft shop, for tractors and agricultural equipment, i got a new front drive shaft and new ujoints fitted off of irrigation equipment for my 95 disco, all said and done it was 275 dollars, dealership wanted 750 for driveshaft, and 75 dollars per ujoint (2) and 2 hours at at 95 an hour, over a grand easy. I got a new drive shaft installed and it is even stronger than the discos stock for less than the labor and Ujoints alone.
Old Jan 10, 2006 | 11:28 PM
Bait's Avatar
A 95' is totally different.
Old Jan 11, 2006 | 12:33 AM
mikemeyer0's Avatar
Or you could call Bill over at Great Basin Rovers, he can build you a HD double cardan, or check out Tom Woods, they custom build off road driveshafts, and have built many for LR's.
Old Jan 11, 2006 | 03:48 AM
MadBilly's Avatar
Whats the difference?
Old Jan 11, 2006 | 02:05 PM
mikemeyer0's Avatar
ORIGINAL: MadBilly
who you talking to?
Old Jan 11, 2006 | 04:33 PM
MadBilly's Avatar
bait...sorry i should have quoted him....i am asking the difference between the drive shafts and universal joints, in relation bewtween the two models, and why he couldnt get one made from a tractor place?
Phototone
Apr 24, 2008 05:15 PM
jdelp
Aug 9, 2007 07:36 AM
shagybruce
Apr 2, 2007 09:51 PM
millejdq
Jan 11, 2007 12:00 PM
dpeek
Sep 4, 2006 11:11 AM
