Sponsored by: CARiD
undercarriage shield identification
Old Feb 9, 2013 | 04:45 PM
robersonb's Avatar
Default undercarriage shield identification
I've been working under my 2000 D2 and when I got under it this weekend, this was laying under it. Can anybody tell me where it came off so I can figure out how to put it or another one back on?
Also, any ideas why my rover has the emergency blinkers going when I plug the negative ground back on the battery and then turn the key on? I have the security unplugged. Only way to turn blinkers off is to unplug battery again. as they stay on even when key is pulled out.
https://picasaweb.google.com/1142119...eat=directlink
Old Feb 9, 2013 | 06:51 PM
wreckdiver1321's Avatar
Linky no worky
Old Feb 9, 2013 | 07:32 PM
robersonb's Avatar
Sorry, try this link.
Old Feb 9, 2013 | 09:02 PM
Cat heat shield?
as for the flashers going, the BCU controls that via IDM relay pack that is part of the fuse panel. So could be a ground on line that commands BCU, or fried IDM. Or maybe alarm is trying to tell the world you tried to steal the truck.
Old Feb 9, 2013 | 09:27 PM
robersonb's Avatar
Default shield
Savannah
quite likely the alarm, although I didn't know if it would do much sinc it is unplugged. However, I had put on and taken off (negative battery post several times before I saw someone with a suggestion about unplugging it. I've been working on this thing for several months. I hope its not BCU and I don't know what the IDM is but I will look it up. My interior dome lights don't work either by doors or manual and with replaced lights no fuse out so I was going to open up and look at wiring around BCU anyway.
Cats cover makes sense with where I found it so will look at that as soon as I get under car again and I can take a look at Manual or RAVE and compare.
Cat heat shield?
Old Feb 9, 2013 | 09:28 PM
robersonb's Avatar
Anything special I should do when I plug the alarm back in?
Old Feb 9, 2013 | 09:32 PM
Have a working key fob. The IDM and BCM have to sync up with each other, that can be forced by leaving truck with ignition in position 2 for say 10 minutes.
Old Feb 9, 2013 | 09:42 PM
robersonb's Avatar
Default key fob
So what do you do if you don't have a key fob? I bought the truck with only 2 regular keys.
robersonb's Avatar
Maybe that is an issue since it has been left weeks with no battery in it?
Old Feb 9, 2013 | 10:54 PM
robersonb's Avatar
ok, got it out of super lock mode, pretty sure it was anyway, had an m and an s lit up. I plugged the security back in and then did the key turned back three times in door or something like that. Took a few tries but it finally took or else it got tired of yelling at me and turned the blinkers off. By the way I did start by having the key in 1st position for 15 minutes prior to turning it to position 3. As soon as I turned it to position 3 the blinkers went off and I tried the key in the door switch turned back three times.
bangkuaidiscovery04
Mar 27, 2012 05:58 PM
mbonthenet
Mar 2, 2012 01:05 PM
RealRitzcracker
Detailing
16
Mar 5, 2009 09:57 AM
beecheril
Jan 23, 2009 08:28 AM
Vorhees
Aug 25, 2008 05:07 PM
