Sponsored by: CARiD
VDO Oil gauge electrical
Old Mar 30, 2013 | 01:40 PM
schweiger's Avatar
Default VDO Oil gauge electrical
Hi All,
I installed a new VDO oil pressure gauge. Today I installed the VDO sender and adapter and attached the wire.
The lights on the gauge are connected and working. Below that I have a green/white wire on drives side that is connected as it was before and a white wire on passenger side of gauge with a bullet connector.
Anywhere I try and connect the white wire, that seems logical send the gauge needle to max.
I'd rather not fry anything so any advice would be appreciated.
Where does the wire go? do I have a short?
Thanks
Steve
Old Mar 30, 2013 | 01:47 PM
Did you run a new wire to the sender or are you using the one that went to the oil pressure switch? Any wiring diagram come with your kit? Helps if you put model and year in signature, a 110 has different wiring from a LR3.
Old Mar 30, 2013 | 02:15 PM
schweiger's Avatar
Sorry. Thought I did. It's a 1993 defender 110.
I didn't run a new wire. Was trying to use existing.
Old Mar 30, 2013 | 02:55 PM
Perhaps a test would be to run some simple wire out the window and under the bonnet and connect to the sensor and gauge, just to verify that everything works. Then take on the issue of what wire you'll have to change, or if running new wire is needed. In most Rovers with just an oil pressure warning light, plus volts comes to the light, then the other side of the light is connected to the oil PSI switch, which grounds it to turn on the bulb.
Even some old gauge senders varied resistance to ground. Some new gauges "float" above ground electrically, and need both sides of sensor run back to gauge. Some sensors have one terminal, and use the blockl for the ground conection. Some sensors have two terminals, and you ground one of them. And they even have a sensor with two terminals, one drives the gauge and the other the warning light.
VDO makes good gauges, used in lots of things, they have a manual http://www.dnvdo.com/files/8207/2012...68ab30a80a.pdf that covers many of them. You may well have to end up running dedicated wires.
Old Mar 30, 2013 | 03:53 PM
schweiger's Avatar
Mine has two contacts. One to the gauge and one to warning light. if I'm not mistaken.
Ill check the manual.
Thanks
Perhaps a test would be to run some simple [/B]wire out the window and under the bonnet and connect to the sensor and gauge, just to verify that everything works. Then take on the issue of what wire you'll have to change, or if running new wire is needed. In most Rovers with just an oil pressure warning light, plus volts comes to the light, then the other side of the light is connected to the oil PSI switch, which grounds it to turn on the bulb.
Rover_Hokie
Feb 2, 2014 03:52 PM
Hercu
Oct 9, 2013 08:37 PM
lipadj46
Oct 17, 2010 06:34 PM
mordor110
Dec 9, 2007 11:04 PM
Fonzie
Oct 15, 2007 01:47 PM
