Sponsored by: CARiD
Violent, Sporadic Vibration
Old Apr 11, 2012 | 08:46 AM
  #21
antichrist's Avatar
Originally Posted by FieryRebel28
Well, I took the Disco to a very reputable shop in town. They balanced and rotated the tires, and also did an alignment...no more wobble. I had them inspect everything that was mentioned in this thread and it all looked good. I even went so far as to hop down in the bay with the mechanic. He said I need new tires and that one had no weights on it at all. I guess I'm one of the lucky ones
Cool, glad it turned out to be something cheap.
x2 on thanks for reporting back.
My only concern is that changing shocks and hub bearings, if that's all he really did, won't affect the alignment. Next step I would do is remove the steering damper and (carefully) drive it where it would wobble before and see if it does it again to any degree. If it does, you still have some issues.
It could be that the bad alignment was enough to get it going beyond what the damper is able to mask.
Old May 15, 2012 | 08:45 AM
  #22
FieryRebel28's Avatar
Hey, guess what?! The damn wobble came back with a vengeance and sent us flying off the road the other day. I actually noticed a "little" wobble a few weeks ago. Needless to say, the Disco is going straight to the shop today
Old May 15, 2012 | 10:44 AM
  #23
antichrist's Avatar
The mechanic really needs to go through the list I linked to in post #10, step by step.
Just a visual inspection won't do it. Offer to do the steering wheel wiggling if he doesn't have someone else to.
I'd remove the steering damper until you get it sorted out.
Old Jun 6, 2012 | 12:25 PM
  #24
HELP! I took the Disco to a different shop and they want over $500 just to take apart a few things and make sure it was all put back together properly when the previous owner replaced the ball joints. Here's the issue AFTER I had an alignment/balance/rotation completed.
-Violent Vibrations AFTER hitting a bump or imperfection with the RIGHT time only. The left tire blazes over anything without a hiccup. It goes away if I veer left.
I need to have the Disco ready for a road trip in 7 days...oh my.
Old Jun 6, 2012 | 01:11 PM
  #25
discoguy96's Avatar
check your swivel pin preload
https://landroverforums.com/forum/di...preload-36607/
Old Jun 6, 2012 | 01:47 PM
  #26
Do you know off-hand which bearings and washers I need to replace when I check this? There are a ton listed on the parts site...I'm new at this so don't hold the dumb questions against me
Old Jun 6, 2012 | 02:03 PM
  #27
antichrist's Avatar
You need the rebuild kit for a Discovery 1 w/ABS. Rather, you might need that, if it's your problem.
Has anyone gone through the list I posted of things to check? The entire list.
Old Jun 6, 2012 | 02:22 PM
  #28
I am unsure. I provided it to the shop I took it to, but I was not impressed. They seemed to have a know-it-all attitude and I felt like they were ignoring my suggestions :/ I can't check it on my own, so it looks like I'll have to take it to yet another shop...
Old Oct 6, 2012 | 05:08 PM
  #29
lightwriter's Avatar
Hi, did you resolve your issue? What was it?
CaptainSlow2008
Sep 12, 2010 05:53 PM
jck09
Apr 17, 2010 08:20 PM
ColoDisco
Aug 14, 2009 01:33 PM
bangkuaidiscovery04
May 11, 2009 10:00 PM
RovinLA
Dec 26, 2006 09:23 AM
