Sponsored by: CARiD
what is the correct ATF for a 2003 Disco II?
Old May 29, 2013 | 04:06 PM
bcolins's Avatar
Default what is the correct ATF for a 2003 Disco II?
Doing a partial transmission fluid change on my 2003 Discovery II. I picked up Castrol Transmax Dex/Merc. Is this the right stuff?
Brian in Austin
Old May 29, 2013 | 04:17 PM
Dexron III rated. If it says that on the bottle then you are good to go.
Old May 29, 2013 | 06:42 PM
Rovin4life's Avatar
Dex three and above is fine.
Old Jun 18, 2013 | 05:35 AM
clark22's Avatar
according to the RAVE the auto as well as the manual box should have the oil changed on every B service which is every 24 000miles or 40 000km. the Rave also states auto box filter change on first B service only. this is strange - what happens after?
it is the diffs that should have an oil change at 96 000km.
Old Jun 18, 2013 | 06:49 AM
If it was changed by Rover at the 30,000 K service, you should be fine till the 100,000 service. As t gets older and if you wheel a lot you might consider changing the fluid every 20,000 K.
Old Jul 14, 2018 | 01:23 PM
Drew Allan Hillier-Cicconi's Avatar
Exclamation Transmission fluid for Discovery II
Do any of you lot read the Discovery Owner's Handbook? I have the 2004 discovery II SE7, and on page 239, it states the following: "Automatic Gearbox: Use Castrol TQ Dextron III or Transmax Z." On page 240, it states the Automatic Gearbox takes 10.2 quarts of ATF or 9.7 liters. It is very hard to completely drain the transmission, so go to the British Atlantic video on how to change the transmission fluid.
Hul1gan
Sep 27, 2016 09:10 PM
Charliebearuk
Apr 19, 2012 06:25 AM
DiscovermeNOW
Engine & Internal
Aug 14, 2011 06:09 PM
RoverR
Nov 8, 2010 01:03 PM
kcirtap
Sep 20, 2010 05:02 AM
