Sponsored by: CARiD
What Did this motor come out of ?????
Old Sep 9, 2017 | 08:06 PM
so what your saying is someone pulled the pump off a motor
Old Sep 9, 2017 | 08:18 PM
earnies2's Avatar
Default no pump
No what i am saying is the motor i bought never had a power steering pump there is a pulley holder bolted in place of the pump and it holds an idler pulley in place of the pump...it also has a P38 thermostat so i think it came out of a P38 .
Attached Thumbnails What Did this motor come out of ?????-20170907_195717.jpg
Old Sep 9, 2017 | 08:26 PM
Well I can see the AC compressor is missing than the idler and the empty spot where the PS pump goes. As for the P38 thermostat it may well be never paid much attention to it. From looking at your off angle pics I would say someone pulled the motor and left the PS pump connected to the lines and same with the AC compressor.
Old Sep 9, 2017 | 08:51 PM
earnies2's Avatar
Default look at the pix
if someone pulled the motor and left the power steering pump connected to the lines than explain why there is an idler pulley ware the pump is supposed to go and if they pulled the pump there would be no pump or pulley
Attached Thumbnails What Did this motor come out of ?????-20170907_195717.jpg   What Did this motor come out of ?????-20170907_170052.jpg
Old Sep 9, 2017 | 10:03 PM
They all have a idler there.
Attached Thumbnails What Did this motor come out of ?????-serpentinediagd1.jpg
Old Sep 10, 2017 | 11:57 AM
earnies2's Avatar
Default power steering
I might be missing something i need to go and look at the disco that this motor is going into and see ware the power steering pump goes thanks for responding i appreciate it do you know how to tell the difference between a 4.0 or 4.6 I will probably take this motor apart and do the heads. mabe rod and main bearings and a timing chain...not sure how far i will get into the motor until i get into it
Old Sep 10, 2017 | 12:22 PM
only way I know to tell is by dropping the pan and looking at the crank if memory serves. There may be a better way.
Old Sep 12, 2017 | 02:10 PM
OH+D's Avatar
4wd High
Yes that is a P38 engine. The dead giveaway is the motor mount design. The front cover is also completely different (different oil filter location). You would be able to make it work in your application by swapping the front cover and accessory drive with your existing parts. I would recommend replacing the oil pump if you do so.
Adam
lr2001silver
Jun 27, 2013 07:27 PM
outdoor7or24
Apr 2, 2012 01:29 PM
wheelgarage
Nov 12, 2011 09:04 PM
RenoHuskerDu
Oct 31, 2011 07:51 AM
Cosmic88
Mar 9, 2011 06:53 AM
