Sponsored by: CARiD
whine in my 99 disco2
Old Feb 26, 2007 | 11:28 PM
9699rover's Avatar
6th Gear
Default whine in my 99 disco2
just wondering if any one has had a whine from under the front on accellation mainly at speed of 20-30mph and 60-70mph only when pressing gas,i think it is either the front diff. or the transfer case??it does have the ACE system, has anyone had this whine before??? thanks jason
Old Feb 27, 2007 | 11:25 AM
Default RE: whine in my 99 disco2
Have you had your front drive shaft rebuilt installing new u-joints in the double cardon? This is a common problem with D2's, you can't grease the old u-joints and they get noise then fail, sometimes taking the tranny with them.
Mike
Old Feb 27, 2007 | 07:23 PM
9699rover's Avatar
6th Gear
yes it has a new driveshaft in the front greaseable u-joints, i have not had it long, but the whine has me puzzled, how bad are the transfer case's in these for noise??
Old Feb 27, 2007 | 08:39 PM
The t/cases are pretty good, have few problems and do have a slight klunk and a little whine.
How long has yours been making noise? Are you sure it is not one of the belt pulleys or the tensioner?
Mike
Old Feb 27, 2007 | 10:00 PM
9699rover's Avatar
6th Gear
i have only put about 1200mi on it , but it has 157,000 mi on it i was a ASEtech at Ford for 4.5yrs, but i have not had a chance to check it out real good, but it is a gear whine or bearing whine i just can't pin point it because it has to be in gear under accel. the rear seal on the transfer case leaks, got anyideas the rover is in excellant shape, very well took care of , that is why the whine kind of puzzles me??
jason
Old Feb 27, 2007 | 10:52 PM
tailchaser0527's Avatar
My '99 also makes a similar "whine". At highway speeds,if i'm tryingto maintain speed,andthe engine isn't putting power to the wheels, just beforeI completely let off the gas a whining noise comesfromeither the tranny or transfer case (I think). So i'm interested to seewhat your diagnosisis.
Old Feb 27, 2007 | 11:08 PM
9699rover's Avatar
6th Gear
cool man how many miles is on yours? that is the whine i am after!! i will keep all findings posted
Old Mar 1, 2007 | 02:02 AM
Mine has about 115k on it, but i just got it a year ago. Don't know if the tranny has ever been serviced, but on my next oil change i'm gonna do it. If the service doesn't fix it, i'll probably just live with it for now, i hope it's a typical rover noise.
Old Mar 7, 2007 | 03:45 PM
jason, I just changed the engine oil in mine, i'm still waiting on the tranny gaskets. Iusedfully synthetic engine oil thistime, and the whine seemed to go away, for now.Keep me posted on yours, and let me know what you find out. Jimmy
9699rover
Mar 3, 2007 02:10 PM
Brad S1
Jul 13, 2006 08:48 PM
kcabpilot
May 30, 2006 02:10 PM
2k2wranglerx
Mar 12, 2006 06:44 PM
pzwerner
Nov 8, 2004 11:22 AM
