White smoke out of exhaust
Recently bought back my 2000 Discovery 2 from my cousin. He put 130,000 miles on it (201k total mileage), maintained it fairly well, but sat for periods of time. After getting it back I worked and fixed all the little things that were wrong with it, nothing major mechanically, an alternator and cosmetic stuff (lights trim wipers). I recently was driving it and white smoke started pouring out of the exhaust, usually this means coolant is getting into the exhaust and it's the head gasket, in this case according to one mechanic it's not. It is burning oil internally and according to him needs to be shipped out to a machine shop to check the valves and pistons. I am taking it to a land rover dealer today to see what they have to say and what they think I should do. Chances are I'm just gonna rebuild the whole engine, any ideas or thoughts? Thanks -
Chances are, fuel tank has water in it. Is there a water separator inline on this. If not drain tank, or install a water separator and drain periodically until tank is empty. Also, never fill tank while a tanker is filling the tanks at the station where you are getting fuel. While filling their tanks, water, sediment and crap us stirred up and ends up in your tank. I had a write up in the diesel forum a couple of years back. White smoke, crazy knocking, etc. had to drain separator every 30 miles or so. Dirty crappy water filled my separator. Just a thought, mind you.
elgatomiguel (12-14-2019)
lets go back to the original post "I recently was driving it and white smoke started pouring out of the exhaust, usually this means coolant is getting into the exhaust and it's the head gasket, in this case according to one mechanic it's not. It is burning oil internally and according to him needs to be shipped out to a machine shop to check the valves and pistons." this is why i suggested oil people........ it happened to my other LR
gasket blown around 3rd and 4th cylinder..
![Embarrassment](https://landroverforums.com/forum/images/smilies/r8fZzl5.png)
yukonridin23
18
01-04-2010 11:08 AM
