Sponsored by: CARiD
won't start
Old Nov 22, 2011 | 08:45 AM
billyw's Avatar
4th Gear
Default won't start
My 1996 discovery won't crank sometimes,motor turns over fine but not fireing.Wondering abought alarm sys.any way to check it and see if that is the problem.Had a Jeep once if the battery went dead I had to ret it in order for it to crank.Any help will be much app. THanks
Old Nov 22, 2011 | 09:09 AM
Another won't crank but turns over, when will it end.
If the engine is cranking, then it is turning over. If it is turning over and won't start that is most likely either the fuel pump, fuel filter or crank sensor.
What have you checked so far?
Old Nov 22, 2011 | 10:09 AM
Got spark? Suspect fuel pump or fuel pressure regulator - schrader valve right side fuel rail 32-34 PSI.
Got no spark? Suspect Crank Position Sensor, if it fails when trying to start it may not throw a code.
I don't have my RAVE in my pocket, but I think the alarm immobilize inhibits crank relay, so if it is turning over may not be the alarm.
Old Nov 24, 2011 | 10:33 AM
Rovin4life's Avatar
don't forget a cam signal code, have my ecu stuffed with water and wouldn't start till dry.
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
