2007 Freelander 2 drivers seat not moving properly
Old Oct 17, 2023 | 02:34 PM
Harris1's Avatar
Default 2007 Freelander 2 drivers seat not moving properly
Hi all, 2007 Freelander 2 drivers seat doesn't move properly.
The seat moves up and down as it should but the front/back and backrest angle have very limited movement.
It moved all the way to the back and full reclined this afternoon and will now only move about 2/3cm forward and maximum 45 degrees for the back rest.
I have looked under the seat and can hear/see motors moving. I cant see any damp damage (although not entirely sure where to look for that).
Does anyone have any suggestions?
Thanks
Old Oct 17, 2023 | 05:30 PM
flybd5's Avatar
Thanks
Sounds like it needs lubrication. Use lithium grease for best results, comes in a spray can.
Old Oct 19, 2023 | 04:20 AM
guy's Avatar
guy
I have gone through this before. The seat control module needed reflashing. This is done with SDD,, of course.
I don’t recall the catalyst for this situation.
Cheers!
Old Oct 19, 2023 | 08:04 AM
flybd5's Avatar
I've only run into two reasons for a module to have to be reprogrammed.
1. The module had water damage and needed replacement.
2. The owner of the car thought he didn't have to read instructions and was monkeying around with SDD without the adequate power supply hooked up to the car.
Old Oct 20, 2023 | 05:22 AM
guy's Avatar
guy
This is a common occurrence on Jags too.
Harris1
LR2
Oct 17, 2023 05:30 PM
river otterman
Freelander
Aug 25, 2018 01:16 AM
robbb
Oct 25, 2013 06:22 PM
Brendan Brady
Freelander
Sep 6, 2012 05:43 AM
BlackAvon
Freelander
Oct 20, 2009 05:28 AM
