2008 LR2 Steering Pump Replacement
Old Jan 21, 2019 | 09:48 AM
p_gill's Avatar
Mike,
Let me know if the Reservoir and fluid fixes your problem
You can use
Pentosin CHF202
or
Pentosin CHF11S
11S is slightly more expensive and possibly easier to find.
If you are planning a trip to the arctic in the winter with temperatures below -40 then 11S is the better choice
It doesn't get that cold where I live so I just use the same fluid as was filled from the factory the 202
Because you were able to get so many mile without many problems it would be useful if you could let me know the answer to the following
- Oil change - How often? What oil? What filter?
- Gasoline- What Octane? Preferred brand? Top Tier?
- Sparkplugs - what brand? How often?
Also if you do decide to use the list for maintenance items please let us know what you find
Good Luck
Paul
Old Jan 21, 2019 | 09:57 AM
razorgaze's Avatar
hey paul, i use liquimoly full synthetic 5W-40 i believe is the weight and i change it myself every 7500 miles. This is the
Oil Filter Oil Filter
i've been using. I always use 92+ octane at whatever station i need to access (mostly QT by my house and the occasional shell, exxon and chevron).
Honestly, i've not changed the spark plugs but that is next on the list.
New reservoir arrives tomorrow so i'll let you know!
thanks again
m
Old Jan 21, 2019 | 11:47 AM
p_gill's Avatar
Mike,
>200K and you use LiguiMoly ---- that makes sense!!!!
I don't add any oil between changes and I am assuming that you don't as well
I am using Mobil 1 0w40 (5 quarts for $20 on sale Amazon Prime)
If the Mobil 1 wasn't so much cheaper I would use LiguiMoly instead. (From what I've read on Bobistheoilguy LiguiMoly is the better choice not taking cost into consideration)
I do use 91 Octane, in the Peoples Republic of California we can only get as high as 91.
Moving on to Spark Plugs
Here is what I am using
Denso (5344) IKH20 Iridium Power Spark Plug, (Pack of 1)
https://www.amazon.com/gp/product/B000CJ46HW/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
Link about replacing the plugs
Freel2.com - View topic - Reduced Engine Performance - spark plugs?
If you have the time you should mark the spark plugs (to show the intake valve location) and take some good picture
The Volvo Technical bulletin explains what needs to be done, its a good read about our engine consuming Oil
Here is what the Australians have to say about our engine
Volvo 3.2 SI6 engine: B6324S | Oil Consumption
And here is the technical bulletin from Volvo for assessing the spark plugs
http://australiancar.reviews/_pdfs/V...ion_201204.pdf
Take care
Paul
Old Jan 21, 2019 | 11:53 AM
razorgaze's Avatar
paul, you're the man, man. A wealth of info. And here's the
LiquiMoly LiquiMoly
i get.
Also, i do in fact have to add a little oil between changes. It's the damnedest thing too as i have no leaks or anything. I recently replaced a vacuum leak in the dipstick and thought for sure this would solve the top-off issue - nope.
I will post all activity and success/failures thereof
m
Old Jan 21, 2019 | 07:37 PM
p_gill's Avatar
Black sharpie mark shows intake valve location
I believe these are the original plugs for the 2010 S80
removed at 124k miles
#3 coil was slightly discolored
#3 plug is the darkest of the group
Old Jan 26, 2019 | 05:05 PM
razorgaze's Avatar
hey paul, so...
I followed the video and still have the squeal when i turn; however, it does seem to turn easier. And The video, though straightforward, left me scratching my head a few times, so it's quite possible i have air in the system.
I got the reservoirs configured and hooked up. It didn't immediately occur to me that with the key in (but the car off), turning the steering wheel puts pressure on the lines causing the old reservoir to fill with fluid. However, i failed to turn on the engine while the two were connected so i never got the old fluid fully out. By not doing so I likely left air in the system as the reservoir swap caused some fluid to escape.
I will now look into how to completely bleed the system IF having air in the system could cause it to squeal. Honestly, i think it's the belt. After the install, i took it to the car wash to clean off the engine because i got a little fluid in the bay. Plus, i just like to keep it dusted off. I keep the car running in case anything gets wet that shouldn't will quickly dry. Well, it started squealing without any movement on the wheel. My theory is water got on the belt. as i mentioned, about 1/3 of the belt is gone, like it was somehow perfectly shaved off. Perhaps without the full strength of the belt the squeal is actually the belt slipping.
Anyway, just wanted to post an update. The belt has to be changed and I've decided that with 211K miles on it, might as well just changed all the pulleys, water pump, thermostat while i'm in there. Those parts will arrive next week so i'll keep you posted.
m
Old Jan 26, 2019 | 06:17 PM
p_gill's Avatar
Mike
congratulations you are on the right path
it does sound like the noise is coming from the belt or pulley
as for air in the system it’s easy to tell just start the engine and remove cap for the reservoir the bubbles will be obvious
good luck
Paul
LICKDLISH
Mar 17, 2017 10:28 AM
desertdweller
LR2
Jan 5, 2015 09:58 AM
ColoDisco
Apr 9, 2010 11:25 AM
Robeye
Mar 11, 2008 12:16 PM
