Best battery replacement?
Old Oct 23, 2016 | 12:14 AM
lazerbrains's Avatar
Default Best battery replacement?
i am needing to replace the battery in my LR2 2009. But due to the near constant battery drain on these vehicles, is there a better option for a replacement battery? Would a deep cycle battery help? Any info would be helpful.
Old Nov 15, 2016 | 12:36 AM
Anybody have a good suggestion for a battery replacement? Anyone know how Bosch stack up to diehard batteries?
Old Nov 15, 2016 | 01:25 PM
LR2driver's Avatar
There are three main battery manufacturers in the U.S. (I'm assuming you are in the U.S.). They are Johnson Controls, East Penn, and Exide, which are sold under various brand names. I have used batteries made by Johnson Controls (Interstate brand) and East Penn (AAA brand) and so far I've found the East Penn battery to be better.
I measured the charges on both batteries when new and the AAA battery measured higher than the rated CCA while the Interstate battery measured slightly lower. That's very anecdotal since you would need a larger sample size to make any meaningful conclusions, but that's my experience for what it's worth. East Penn batteries are sold under the AAA and Napa brand names.
If you do some online research in the car forums, I think you'll find that people rank the batteries as 1) East Penn, 2) Johnson Controls, and 3) Exide.
Old Nov 15, 2016 | 01:28 PM
Thanks, that is very helpful information. Do you know where Diehard or Bosch land inside of those 3?
Old Nov 16, 2016 | 12:35 PM
LR2driver's Avatar
I believe Johnson Controls makes both Diehard and Bosch batteries. If you are settled on buying one of these two brands, since they are essentially the same product with different labels, pick the one with the better warranty since that will vary by brand and seller.
Old Nov 16, 2016 | 01:09 PM
Great info! Thanks!
Old Sep 18, 2017 | 12:10 PM
When replacing the battery, do I need to so anything special? I don't want to trip any anti-theft device or anything. Is it as simple as disconnecting the old battery, and putting in the new battery?
Any info would be helpful before I get started.
Thanks!
Old Sep 25, 2017 | 09:54 AM
SoCalLR2's Avatar
As long as you haven't let the battery get very low where you start having issues with various modules, you can safely disconnect and reconnect a new battery without anything special required.
batard
Dec 21, 2015 07:38 AM
gpelite
Oct 5, 2015 06:08 AM
gribur
Apr 10, 2014 08:29 PM
legendbridges
Jul 10, 2012 07:04 PM
jrkstore43
Aug 7, 2009 06:20 AM
